Carlospsalazar
New member
I need help. Working on a mostly stock C3. I would love to take this computer and carb and float it down the river but alas I am in California and need to make it work.
My problem is I am getting code 23 and the air fuel mixture is not clicking. When I plug my scanner in or ground E and D it does click. I have followed the code 23 guide from the book.
I noticed there is no RPM signal making to the computer. The “mostly stock” is that it has a non computer controlled distributor and the plug is undone. Would no RPM signal make the whole thing not work? I ran the diagnostic to the end and it said the ECU was bad. Swapped out the ECU and having the same problems. I don’t want to keep throwing parts at it. You guys seam to know a ton about these cars. Can someone help me with the answer to this specific question? I really appreciate the help.
