F
Fast Ed
well I'm back, I had to put the project on hold for a year or so but it is progressing quite well now. The last major thing on the to do list was the first one encountered "no brakes".
everything has been bleed by several shops and everything is new except the proportioning valve.
In testing the brake system and plugging the line to the rear brakes down stream from the valve I get resistance in the pedal. Doing the same to the front brakes and hooking the rears back up there is no brake.
The question is could it be the valve that has been the problem all along? Short of replacing it is there a possiblity that is simply plugged?
She is so close to the road I can taste it.
Thanx
Ed
Thanx
Ed
