76 radiator removal
  • Thread starter Thread starter k9judge
K
k9judge
Hello to all
Need a little help here, am attempting to remove radiator from my 76 (no air) Have drained,removed hoses,atf lines, air intake, and two upper radiator hold down brackets,fan blades, what else am I missing? fan shroud and radiator still seems locked in place pretty solid. And theres not much wiggle room. Any help would be appreciated.
Denny
There is no "easy" way to do this. It will help to remove the radiator support bolts. 6 bolts accessed from the wheel wells. Then you can push the whole assembly forward enough to clear the suspension. Be happy that you don't have A/C.
