76 Stingray power steering fluid leak???
  • Thread starter Thread starter hollywood76
H
hollywood76
My 76 Stingray's power steering moans, then 1/2 the amount of power steering fluid goes away almost immediately. A little later, all of it is gone, but I don't see any real leaks under the car.
Any ideas???
Much thanks!!!
Glenn (hollywood76):confused
Hmmm...did you recently buy this car and has it been sitting for a while?
Probably your power piston is leaking. Break out your Corvette catalogs again!
Been there, done that, got the t-shirt.
I was able to check and add ps fluid with one hand, in the dark, in under a minute. (hot or cold engine, and without getting burned if the engine is hot)
My ps leaked for several years, requiring fluid about every 10-12 days. The last year of the leaking ps I had to add fluid after every drive over 30 miles. (daily, sometimes twice)
I had replaced several components over a period of several years, but the leak persisted. I did not achieve success until I replaced every component, all at once. I used all new parts from Ecklers.
I think your fluid leak must be pretty big (like mine was) if you are not seeing a leak and it is disappearing so quickly. Mine was covered in fluid under the vette, I wonder if yours is shooting out when under pressure? Can you check the hoses?
This is something that you will definitely want to take care of soon since it is moaning and fluid is disappearing so quickly.
Heidi
Yes, it was sitting for 2 years +/-. I got it from my cousin and it just started the power steering problem all of a sudden.
Thanks to all for your input - I'm kinda new at this ;shrug
