1
1yy07
77-82 low fuel warning module,. can annybody fix these things??????????:W
Where was the solder broke????
Mine has never worked either!
YUP!!!!I performed this repair about 10 yrs ago, so my memory may be off. The low fuel light should have a small circuit board. On the back side are some soldered joints. The split in the solder was very small and almost not noticeable. I think I used a continuity tester to check the solder and that's how I discovered the split in the solder joint. Hope this helps.
