78-early79 am/fm power antenna
mkapp7879
Beecher, Ill.
78 Pace,black 79 and white 79, all L82s
This is a nicely restored power antenna out of(as I'm told)a 21K mile 78.
Upon opening it up and overall condition I believe the mile statement is true, it's mint! It's also numbers/date correct for most pace cars.
I replaced the nylon cable that pushes it up and down and replaced the harness with a CORRECT harness that goes all the way to the relay so splicing wires isn't necessary(altho it's probably easier to splice them).
Cleaned it up a bit and lubed.
I also have all the mounting brackets, bezel, co/ax cable, nos relay, and can put together a correct forward harness if needed for additional cost.
The bare wires in the photo are simply stuck into the connector to enable bench testing.
$200 plus shipping.
