1
1978L48jafo
Two questions I am using Northern's HP rebuild kit with the flat top pistons and crane street cam. I have also purchased performance heads 58cc casting number 14014416. The heads have larger valves and competition springs basically the works done.
Question 1 Did I take it too far for a Daily driver regarding compression? I obviously started at 8.5:1 and my best guess is I am at least 10.5:1????
Question 2 The sender hole is smaller on the new casting any suggestions? I checked and the heads could have been used on a 78-86 305. I also purchased an aluminum performer intake maybe if I am lucky there will be a plug I can use and move it up top??
I would appreciate suggestions
John aka JAFO
:confused
John aka JAFO
:confused
