Rob79er
I bought a Remanufactured Distributor from Auto Zone.
The base of the shaft is seated in the hole but the shaft (distributor) will still rotate side to side even though I have the little C-Bracket up against the shaft and the bolt on tight. The only thing that I can figure out is that the base of this new distributor is not as wide as the old one .
Take a look at the base of the shaft in this pic. It is flush at the bottom but not on the sides of the circumference. It has an 1/8 inch of play before it comes up against the side.
http://www.photohost.org/gallery/sh.../cat/500/page/1
Can someone check their disti. and see if they have that play as well.?
The red that you see in the pic is remnants from the old gasket from the old disti --so I am thinking that this Reman is not the same shaft size???
