S
smooth-rider
Hi all, first post but boy I need some advise. I bought an 81 vette that had a cowl fire, engine harness fried, as well as I have to fiberglass a new cowl into place. Easy enough, the big ? original motor has some pitting in one cyl., should be able to be bored. Have done a great deal of reading, one rebuild site showed were the 383 stoker could use standerd junk gas even at 10 compression ratio, becuase of the longer time piston is at top of cylinder, less detenation, not sure if thats feassable, I do wanna run pump 87 gas, it will be a DD for me and my wife.
Stock 190 hp for a vette is a disgrace, would like to get to say 300hp, stock drive line should be able to handle it from what i've read. Now the skinny, might need a new carb might as well add a new intake, all new hoses and wiring, belts, sending units sensors and so on. Maybe more cost effective just to buy a 80+ or 90+ TPI engine tranny with wiring and accs. off ebay to retro fit. Will one of those fit the car and would I have to reweld engine mounts tranny mount and possibly shorten or lenghen or mod the drive shaft.
Car only has 56k on it so I wanna do it good, body off atm and frame has been POR15 Fantastic stuff!!! Energy suspension suspension kit and body mount kit. Have true duel exhaust and plan on not putting the air pump back on, does the ECM have to be redone then? Have the stock lockup 350, can I put a higher stall in and just not hook the wire up for the lock-up or would I have to get a new trans. Tall order I know but any help would be great. Oh ya then there's money, I keep forgeting to water that tree out back.
