LT4man
The lead is a green connector and does not come directly off of the M/C solenoid plug. The lead is spliced in the wire that goes to the plug a few inches back and sticks out through the black wire loom. Follow the 2 wires from the M/C solenoid back to the loom and look for a green connector sticking out of the loom that is not connected to anything.
Connect the Dwell Meter lead to this connector and the ground the Dwell Meter ground wire to a good engine ground.
If you do not find it there, it might be lying between the air pump and the A/C compressor in a wire loom. It can be wrapped in electrical tape. Look for a bulge. Unwrap the tape and you should be looking at the connector!
SAVE THE
SAVE THE
