E
edvette81
Today my factory alatm went off unexpectedly.
moments later found that the drivers door could not be opened with key or any way. Crawled in passenger side, tried to start, but no power to starter. Assume that the security has disabled the starter.
To add to the deliemma, since the door cannot be opened, I need some advice as to how to remedy my situation. Tried to pull up on the rod for the handle; the lever is all the way up.
The hook for the latch which goes over the door jamb pin will not release. I don't want to destroy the hook to open the door to replace the lock assembly, but this seems like my only alternative. Any suggestions?
