as i said, please don't ask how i came to suggest that, lol. been there, done that, lol!! had a problem with the car starting sometime and then getting absolutely not response when i turned the key. everything powered up (gauges, etc and the light worked, so i knew there was power), but no starter response. thought perhaps it was the started switch (located at the base of the steering column) or the rod that actuated it needing adjustment, but a simple meter check on the neutral lockout switch (my console is out and it makes working on a lot of the electrical stuff a lot easier) showed that power was passing through the ignition to the lockout and through that on to the solenoid, so i removed the starter (actually up and down several times. i can now drop a starter within about 5 minutes, lol) changed the solenoid and that seemed to solve that part of the problem once i spent a week trying to figure out why i had absolutely no power getting to the lights or the starter circuit. tested the fusable links, etc and then decided i better start tracing wires. that's how i found the harness connection which i thought i was careful enough not to disturb, but obviously i was very wrong, lol!
good luck. i hope some of my experiences might help you out.
steve
