B
buddaman
HI, I'm a newbie to Corvettes and this forum as I just picked up a 1982. I'm looking for some advice on the brake system.
Symptoms are sporadic pedal, sometimes it will go to the floor, sometimes it's nice and high. When it's high, it doesn't seem to drop if I keep pressure on it, which makes me think the master cylinder is ok. The pads all around are good. I've bled both fronts and all 4 valves on the rears. Some of the initial fluid that came out was sort of dark, but I've essentially changed the fluid at this point on both master resevoirs with all the bleeding. No fluid leaks, in fact, with the bleeding the rubber master cylinder cover gasket gets pulled down and expanded as fluid is pumped out.
I'm stuck thinking that the master is indeed the problem even though once the pedal is high it doesn't drop with pressure, the classic sign I know of for master problems is the pedal dropping with pressure. The lines are good, no leaks, all 6 bleeders shoot fluid so I don't think there's any caliper probs. Just looking for any tricks before I spring for a master cylinder.
Thanks for helping the new guy!
