92C4
New member
Hi, a little over a week ago I purchased my second C4 Corvette, a 1992. It runs and drives great for the most part. Upon bringing it home, I noticed the front brakes functioned as normal but the rears would barely engage. This was on ice, again just bringing it home, but has brought some concern for when I go to drive it this summer. I checked the fluid in the master cylinder, which was full, but looked fairly dark. I decided to flush the entire system with hopes this would solve the issue, it did not. Although when bleeding/flushing the rear lines there was no apparent issue with “extracting” the old fluid from the bleeder valve/brake setup. I removed the rear rubber brake hoses from the lines/calipers and neither were kinked or blocked. My emergency brake does work, but in drive with a little gas the rear wheels spin, (I figure this is typical) same as if the car were in drive, my left foot on the brake and my right just barely on the gas. Neither calipers were frozen and the brakes otherwise appeared to be in good shape. I’m thinking maybe the proportioning valve or master cylinder, but have not found many similar experiences with these cars.
