Haven't been here in awhile and need some assistance. This is one of those cases of if it's not broke don't fix it. Now it's broke
Decided I wanted to pull my injectors and have them cleaned, inspected and tested since the cone looked ok but could be better so I thought. Got them back and everything looked good on them. Installed them back in the car and rebuilt the TB's with new gaskets since I had them apart. Started the car up and I think I got an initial prime (been a few months now and just getting back to fixing it) but TB's started leaking like crazy. Corrected all the leaks and now I have no fuel from the injectors at prime or running. So here is what I have done so far:
- I have pressure at the first TB and in between the two TB's (have a gauge on it and get an initial prime pressure of 12 PSI between). Fuel pump was changed a few years ago to the 85 version. It appears I don't have any issue with getting the fuel there.
- Installed a noid light and getting pulses to the injectors when cranking.
- Looked in the shop manual (chart 4A) and it led me to check the voltage coming from the ECM at pin 430. This was below one volt so this pointed me to the module and coil. Don't appear to have any open or short to ground situation. Decided to just change these two out as the car set for many years before I got it running several years ago. So I now have a new module and coil installed.
Tried to start the car, no initial prime but pressure gauge goes up to 12 psi and then settles down. I just get a couple drips from the injectors.
Any thoughts or suggestions? Going to take the TB's apart again and pull the injectors just to make sure I have done something there.
