UKVETTEHEAD
I wrote a previous post about the Renegade Manifold and how the fuel system could not keep up with the increase air flow. Having refitted the standard intake, i think the engine is still running on the weak side. Recently on a trip to Italy and Switzerland with high alitide passes to drive, the pinking became worse and worse. Maybe the 95 octane fuel was part of the problem. I usually try to get 98 in the UK.
Other post here have hinted that an upgraded ECU may help. I have a comp cam and aluminium heads. This engine has always had a tendency to -pink- but it goes well. Has anyone any thoughts on this. All the engine sensors are the original ones except the O2 which is relatively new. Thanks
