ty82vet
Active member
- Joined
- Sep 13, 2002
- Messages
- 25
- Location
- Chesterfield, VA
- Corvette
- 1982 Bright Red Coupe, 2001 Torch Red Coup
My 82 with cross fire injection has come up with a hiccup. I stopped at a stop light about a month ago and she idled down and cut off (96 degrees outside). She wouldn't crank right back up, but 3 minutes later everything was fine and I drove away. Over the last month, she has done this 3 times. I changed the fuel filter, checked the fuel pump working ok (I have another and will replace), replaced thermostat with a 160 (took out the 195), replaced the belts, checked coolant, and it did it again on Friday (87 degrees outside). My next step was to insulate the fuel line near the block. I'd appreciate any and all help.
