L
lilram
Hello everyone ,new member here with some small issues. where is the fuel pump relay and what does it look like . my manual does not show it, I changed out the pump with an 85 model my fuse behind the drivers seat in the battery box is good and the fuse in the block under the dash is good. the pump work and car runs only when I run a hot wire to the brown wire at the pump, any other suggestions.
