jeanie2002
I have an '82 that keeps loosing brake fluid in the mst.cyl. rear reservoir closet to fire wall. Got under car and can't find a wet spot anywhere. all calipers seem to be dry. On other cars I have had it leak out the back of mst.cyl. itself but usually has a trail of fluid down the booster this does not, i have not pulled mst.cyl away from booster yet because as much fluid as i have lost there should be something wet, No obvious wet spot anywhere. Any Ideas?????
