M
Makogary
I have an intermitten problem with my "check engine light" ,Sometimes it works and sometimes it don't..The bulb and socket are ok. When I turn the key on when its working it lights, When its not working it dos not light. And I am not sure if its affecting the Open/Close loop. It seems to run a little rich and ruff when its not working.. Can anyone tell me how you know if it's in open or closed loop?? Also if anybody had this problem (Check engine light) (On/off) and what caused it..Again all connections are good and are tight, and bulb and socket are ok... Do I have this correct? When you turn on the ignition it tells computor to turn on the light (Check bulb) until you hit start.After that its off until a malfunction occurs.:confused
