- Thread starter
- #21
Hi geekinavette,
I re-verified those two grounds and here is my dilemma...
I disconnected the connector from the map and took the readings from the ecm connector pin as well as from the map ground pin did the same for Coolant Sensor and TPS) and guess what continuity.
Now, when I plug the cable connectors back into the MAP,TPS and Coolant Sensor I don't get continuity (open circuit).... Is this normal ???
Joey
Joey
Did you find/fix those two missing grounds?
