bg84
New member
84 Pwr Antenna Removal:confused Does it take a special tool to reach up to the base??????? Someone please give me a hand on what it takes besides a mericle and six jointed arm to remove and replace the unit. Thanks
bg84 said:84 Pwr Antenna Removal:confused Does it take a special tool to reach up to the base??????? Someone please give me a hand on what it takes besides a mericle and six jointed arm to remove and replace the unit. Thanks
I agree. My normal size arm got up there and removed the large plastic nut.drakefamily2 said:I took rear wheel off and inner fender.
Definitely support the car, safely, with the suspension hanging down. The higher you get the car up, the better! Remove the tire and the inner fender well. Then, if I remember correctly, I found it easier to unbolt the antennae mounting bracket from the frame and remove them together. Because usually the nuts that mount the antennae to the bracket are rusted and seized & then the whole thing just spins in the antennae body or breaks off.
Be patient!! This is NOT an easy job, (just like everything else on the Corvette.) I have short arms too! LOL!
