S
silver84
Car has a miss at idle, high idle, etc. I found a dark brown wire with black stripe, that had a black connection, and unhooked it. It was hopefully the right one, easy too find out in the open. Hooked up the timing light and wallah....the mark is about a quarter inch in front of where the scale starts. Is this bad? I assume you can loosen the dist. hold down bolt and twist it a bit to get it back in shape (by sound).
As you can probably tell, I need some advice here!
