E
esterling
Whenever I turn radio on, my antenna motor makes a noise like its trying to raise the antenna for about 7 seconds and then it stops for about 7 seconds. It then continues starting and stopping over and over about every 7 seconds. The antenna will not raise or retract at all. I have just owned the car for about 3 weeks and the antenna has never moved when you turn radio on or off. I decided to check underneath where the antenna motor was. It appears that someone had cut the white wire going to the motor. Why I don't know. I tried reconnecting the wires but the antenna still didn't work. I disconnected the wires again. I can raise the antenna manually about 4 inches and then it hits something and stops. I can then push it back down about that same 4 inches before it stops. It just feels like something is loose or maybe broken going into the motor. Any suggestions would be appreciated.
ad
