patrickj
Hi all having high idle issues that come and go.I set the idle with iac dis-connected,set the tps at .54 volts idle goes down to about 550 and when i shut it down and re-start it runs up to about 900-1000 hunts around a bit and then drops a little.Sometimes it will correct itself briefly and then it idles up again.Anothe thing that bothers me is the idle and the timing do not change when the connector is unplugged.Brand new motor all new sensors.Throttle screw backed all the way out and push back on the linkage with no effect.Any ideas????
