There is quite a difference from the ’85s to the 96’s in the way of refinement. You are comparing almost the beginning of the C4 generation with the last of the series.
One thing that’s tangible is a ’96 rides noticeably smoother than an ’85. My ’96 is FE1 suspensioned, it’s a pretty decent ride. Only on
rough roads does the car lose some of its composure. The ’96’s don’t seem to have as many rattles as the early generation C4s, another plus is that the ’96’s have antilock brakes (antilock brakes became standard in ’86). The L98 is a great engine, mine was an auto and it was a blast to get the car rolling along. My L98 was reliable and could corner like it was on rails.
Looking over ’96s, I would make sure the optispark is in proper working order. I think the opti has received a bad wrap, but, the opti seems to be mentioned frequently when it comes to “what to look out for” on ’92-’96 cars. I’ve put over 65,000 miles on a 94 LT1 and 53,000 on my ’96 LT4. That’s 118,000 miles with no optispark issues (I just knocked on a piece of wood).
Here’s a link from the Specs section, it might come in handy as you look over Corvette’s that have potential.
Corvette Action Center | Tech Center | Buying a Corvette
This site lists a breakdown of options and production numbers.
1996 Corvette Registry
Going over a ’96 will be a lot like looking over an ’85. You want to go over all of the major mechanicals/electrical to make sure everything is in proper working order. Also take time to look for any signs of previous body work or damage.
If you want a manual and you’re looking at 96’s, your only choice will be the LT4. If you looking at an auto, it will be the 300 HP LT1 engined car.
B17Crew
