cutolds350
Acquired a 86 C4 that has not been run for a while. Car had a no start issue because of no power to the starter and no power to the fuel pump that the previous owner did not know how to fix. I have solved the starter issue by replacing the starter enable relay. I have replaced the fuel pump relay but still no power to the fuel pump. I have tested the fuel pump relay at terminal A and have verified there is power for about 2 seconds after ignition is switched on. I have also verified there is power getting to the oil pressure sending unit. However when testing the connector at the tank there is no power when key is switched on. I also found that the wires were bare and touching on the fuel pump relay connector. Could this have damaged the ECU and be the reason there is no power to the fuel pump? I have not checked power at the ECU where the red wire connects. I'm leaning towards the ECU since the fuel pump relay and oil sending unit are in parallel. Any info would be greatly appreciated.
