86 no horn
  • Thread starter Thread starter aussie
A
aussie
my 86 horns dont work have tested the horns themselves & they both work but have noticed when door open & security light is on if you press the horn button the light goes out could it be a relay if so where is it located
Relay is behind the temp/fuel panel in the center. Easy to get to. Just take your time taking the plastic trim off, then the screws holding the panel in. I was playing around with the steering wheel spring and fried my relay and connection,:eyerole so beware.
Good luck
Gordon :w
