The interior lights no longer come on when the doors are opened, and the door-mounted hatch releases are not working either. Ive checked the fuses--OK; what's next?;help
Keither, Which fuses did you check? Did you check CTSY/CLK fuse? Can you turn on the lights using the dash panel light switch? I would verify voltage at the CTSY/CLK fuse. This will isolate an issue before or after the fuse box.
