87wishin59
Hi All,
My 87 didn't come out of storage very well this year. I need some help.
When I turn on the ignition, the cooling fan immediately starts running. The car will NOT start until the fan stops. Once it stops, the car starts right up. It may run for 5 minutes or all day, then just stops.
I wanted a fresh set of codes, so I disconnected the battery and tried again. I was getting codes 34, 51 & 46.
I had the 34 before this problem started, so I replaced the burnoff and power relays and the 34 code went away. (I checked the MAF with a DVM and it is working)
The constantly running fan kiled the battery. It was about time for a new one anyway so I replaced the battery.
I still have the problem where the primary cooling fan comes on as soon as the ignition is turned on, car will not start while the fan is running (engine turns over, catches for an instant then stops) fan runs for about 2 minutes, stops, car will start. Sit there and idle, then just stop. No codes.
Hard to believe the PROM is bad, hate to just throw a new ECM at it.
All ideas welcome!
Thanks in advance,
wojo
All ideas welcome!
Thanks in advance,
wojo
