8
88red conv
I took my vette for a ride on Saturday pulled in the yard and shut it off. Tried to start it after i opened the garage door it would not start, nothing no click nothing. I tried diconneting the battery, turned the key on shifted thru gears (auto) , tried the new second key. Tried it about 30 min latter started right up.
Last year it did the same thing. Started after about an hour. Bought a new key. Did not have the problem again till Saturaday. Any ideas.
I had a VATS problem early on. Sounds like you didn't wait long enough before trying your new 2nd key.l If this happens again, five minutes, by the clock with no tampering outa do it. If not, then repairs will likely be in order.
