wells
Working on a 1989 c4 l98 modified with a 52 mm BBK twin throttle bodies part no. 1537 . I want to install a BBK twin 58 mm throttle bodies part no. 1544 this is for the 1994 to 1997 LT motor all mounting is the same except the Throttle Position Sensor . Can I use a Throttle Position Sensor and weather pack plug from a LT wire harness . The wires are color coded the same . Black , Blue, Gray Tank You
