New guy can use a little help. I have an 89 coupe that the main fan (the one in front of radiator) doesn’t run. The high volume aux fans turns on and off properly (on 228 & off 210). I have jumped the main fan and it will operate. Question, Is the relay the one on the radiator shroud drivers side under the radiator hose? Does it run both fans? One parts store shows it runs the aux fan and the other shows it runs the main fan.
Thank you
Ken
Thank you
Ken
