89 Vette
bonnie19
Australia
1989 white convertible
Can anyone give me some help in knowing what the problem may be with my 89 Vette.
Went to start it and it would not kick over at first.
After a short while it would just die.
I have been told it could be a sensor problem or something to do with the fuel pump or relay.
Has anyone else had this problem?
Not sure what to try first.
Hi,
I just moved your post to the C4 section. You should get some help there.
And welcome to the Corvette Action Center!! Tell us about yourself and your '89.
Elaine
I always suggest getting a Factory Service Manual - from Helms.com
and also the Chilton and Haynes manuals, too.
They are a great way to learn about your vette quickly.
Do you know how to "pull the codes"? Your car has a computer that keeps track of error situations and will talk to you when you learn how to listen.
You can buy a "code reader" at auto supply places - pehaps US$40. It has a booklet that tells you how to use it, and the meaning of the numeric series of codes read out.
There's an immense base of knowledge here and the guys enjoy helping each other. Tell us your driving/repairing background, in your profile, too. It will help guide us to the best way to help you. We don't want to be talking down, or in gibberish to you.
Thanks Tony for your advice.
Do you have to be a computer geeke to understand the code readings?
I will go explain this to my Husband who is pulling his hair out about this.
He took the fuel relay down to get tested this morning and they said it is fine.
I might give one of the guys from the Vette Club we are members of and ask if any of them have one of these code readers and then maybe we can find out the problem.
This is all new to us and I am so glad we are able to chat to someone that knows all about Corvettes. Thanks again.
bonnie 19
Thanks now as this is all new to us all we have to find out is how to pull the codes and where to take it to be tested.
I wish we understood more about computers than cars as these days cars run by computers also so you don't have to know mechanics !!
Thanks we will look into this though much appreciated
You don't need to even spell computer to understand the code.
The reader is a "plug" that you shove in the socket down by the drivers right knee (it won't go in wrong - it only shorts two of the pins together, you can do it yourself with an unbent paperclip), then you turn on the ignition (but don't start the engine)>
The "Check Engine" lamp in the center panel (called the Driver Information Panel DIP) will start flashing.
Just count the flashes. It flashes each code three times.
e.g. - a "12" is one flash, pause, two flashes ... longer pause -
then one flash, pause, two flashes ... longer pause -
then one flash, pause, two flashes ... really long pause.
then the next code sequence.
all the codes are two digit numbers
the first one is always a 12 (confirms system working)
I think the last one is always the same too, but I'm not sure.
after it shows all active codes, it will repeat the whole thing over.
the codes are usually reset by disconnecting the battery for 30 secs.
some codes can be reset when you start the engine
Look the codes up in the booklet.
Piece of cake. See -- no geek talk at all, you'd never know I'm a serious computer geek. My job is to show CEO's that computers can turn their business around, and you know how reluctant CEO's are to learn or change anything.
Be certain to use good quality premium, unleaded fuel.
Try to avoid ethanol, or unbranded fuel.
I'm having starting problems with my 89 now. I suspect a tank full of bad fuel. It's kinda bunkered up for the winter but my mechanic is gonna be checking out the resistance in the injectors soon. I'm getting some codes, but nothing to help so far. My "Check Engine" light isn't coming on in normal use.
Thanks Tony
I will try all your advice and let you know how we go.
What would we do without you?? It would cost a fortune to take it somewhere for them to play around and do exactly what you have told me. Thanks again!!
Cheers
Tony do you know where we can find a code booklet?? Can you download them from the net? Or if we find the which code can you tell us if you have the booklet?
I scanned the code booklet I have. So far I haven't been able to upload them here. You can go to my MySpace profile and click on PICS. They're in an album called "GM Codes". If you're already a MySpacer, just make a friend request and I'll add you. If not, let me know and I'll make my profile public for a while so you can just go to:
MySpace.com - www.myspace.com/148000427
When you view the pics, you can right-click on each one and select
"save as" then give it a name, probably on your desktop someplace.
You can also select to print them directly.
Good luck. Message me if you have problems with viewing them. I can email them directly to you, also.
(Maybe another poster here can tell me how to post pics, I already put them up on Photobucket but the HTML code didn't seem to display them here.)
OK ,Thanks for letting us know this as my Husband would have freaked if this happened
and the fans came on unexpected.
Tony my Son Adrian has Myspace and has added himself to your friends.
Can you accept him please as we would like your kind help with the code booklet .
I will keep you posted on our things go with the problem and if we are able to sorce which code could be the concern
Thanks again for your help
bonnie19
ha ha I wondered why some 18 yo down under would want to be a friend.
Thanks TOny
My Son Adrian has been onto Myspace and printed the codes now we have to do the hard bit with the paper clip that really makes me nervous incase we stuff something up with the car computer. I will let you know what happens.
Thanks again
bonnie19
Tony we have had a look at the codes list though now realise that one code could have 4 different parts related to it how can you know whick part the code refers too?
Thanks for this advice I will have a chat to a mate in the Corvette Club in WA and see what he thinks . He said he thought it was the fuel pump!!
I have printed off the service bulletin thanks again.
bonnie19
