I forget if that yr had a mass air sensor or if it has the "manifold air-pressure" sensor.
It sounds like a bad MAF or MAF relay. That will make it evil acting at best, barely runs, burps, chokes and backfires and will not take throttle. If it dies it will not restart. Might start up in an hour or day... The gas smell might be the unburned or excess fuel. When the Mass Air sensor fails, it has no clue how much fuel to use, so it just dumps it in. Usually so rich that it can;t run. I am sure that the MAP system has similar symptoms because both systems measure the air flow so the correct fuel amounts can be added for a combustable mixture.
It has a fail-safe mode in the ECM that it SHOULD set after it runs with a major sensor malfunction for a minute or so.. Then it should go to a programmed operation that will allow it to run semi normally to get it home. Also known as the "limp-home mode". If it is NOT going into limp home mode, then that is a clue that the problem may be something other than a sensor.
Is it setting a trouble code? Ck Eng lite on?  Establish what the code is. There are list of trouble codes and what each one means.
I had an injector wire short out once, that made the whole bank short and stick open. That dumped so much gas so fast that it actually flooded the crankcase with gasoline. When it first fired after much screwing around, it squirted liquid gasoline out of the exhaust. It took 3 oil changes and five showers before I stopped smelling gas.
