ThatRyanGuy
So I picked up this 91 corvette about a month ago.
Ill list everything Ive done so far because I can’t fogure it out.
parts replaced-
1) battery 2) altenator 3) fuel tank sending unit 4) fuel pump 5) fuel filter 6) both oil pressure switches 7) fuel pressure regulator 8) ignition coil 9) spark plugs gauges to .035 10) smog air pump 11) serpentine belt. 12) bypass vats.
Done a fuel pressure test-48 psi drops to 40 psi after sitting on run for 45 minutes.
Used a Noid light tester for each injector and everyone pulses.
Car will crank rank but won’t start. If I use starting fluid in the tbi it will start but shuts off as soon as I stop fluid. Check plugs for spark, I have spark to the spark plugs.
The car sat sat for two years, the lcd display is corroded so I can’t read any codes off the dash. Check engine light and battery light comes on when trying to turn key. Security light shuts off when I turn the key. Goes solid when I lock the doors and blinks when I unlock doors to get into car.
What should i be I be looking for? I can’t figure out what my next step should be.
im open to any suggestions at this point.
parts replaced-
