B
Big Red Machine 1
This module plugs in between the air temperature sensor and its harness connector. It tells the PCM air to provide maximum spark advance (usually a 1 to 2 degree increase). Proper knock sensor and other engine sensor functions are not compromised. SLP suggests the use of premium grade fuel with this modification. A 5 to 7 horsepower increase is possible. Call for the most up to the minute vehicle applications. This item works on stock or modified engines HOWEVER it is NOT for use with custom PCM calibrations with advance spark timing. NOT legal for use on pollution controlled motor vehicles.
NOTE: For use with stock MAF sensors and stock tuning.
Sells for $30 shipped. Asking $15 shipped. My unit had 20,000 mi. on it before I sold the car. Pay-Pal or Money Order only please. jtand@crpud.net 503-556-1545 Ouick search # 63010 at link below for info:
http://www.slponline.com/search.asp
http://www.slponline.com/view_product.asp?P=63010
