Hi
Does anyone know what is used to seal (bond) the fiberglass portion of the floor board to the aluminum portion directly under the driver seat? It appears to be some type of epoxy and most of it has broken up. What can I use to replace it? I assume I need to remove all of it that I can see and reepoxy it?
Thank you!
Sent from my iPhone using Tapatalk
Thank you!
