Danny Badabing
I have a 92 LT1 Automatic. Cranking but won't start. I have had a problem with stumbling when stopping at light or I guess under load. Plus, oil leaks. I brought it to my mechanic, and he started diagnosing the problem. Oil leaking onto Optispark from Intake Manifold. Could be causing stumble. Replaced Intake Manifold Gasket. Also, after that it seemed I had a Head Gasket leak because when he added the coolant it was bubbling up or some shit. So, he replaced both Head Gaskets. Water pump was good just replaced gaskets, seal, timing chain cover gasket, new plugs, new AC Delco belt. He also had taken out the opti inspected it and replaced. Car ran for about a week and died. Would not start. Had car flat bedded to another mechanic who is familiar with vettes. He diagnosed car I had a faulty Fuel Pump, replaced, regapped plugs, installed new ignition wires, I had bought a new Petris Optispark and he installed it. All the diagnostics where done - have spark, fuel pressure good, fuel pump working, car started ran for a short time then acted up again while still at shop. Checked codes and decided it may be the ECM. Car actually started brought it home. Had ECM sent out to rebuild. Got it back and it would not start. Just cranked. I resent ECM to make sure it was ok. So here we are about 6 months later and the efin thing still won't start. I have a lawn ornament. Sorry for going on but I had to vent.
Danny
Danny
