This car is doing bizarre things that have me going crazy. Maybe someone can point me to the next step
Symptoms: car exhibits intermitent behaviors on startup. i can start, turn off, and restart the car several times in a row and it will do any number of the following things in random order each time:
1) Super high idle and rich exhaust smell. runs and drives fine, but idles around 1800 in park.
2) No idle: will fire and run fine if I hold the accelerator down just a touch to maintain some revs, once I let the pedal go for even a second the revs fall below 300 and the car dies.
3) Completly normal and perfect operation, perfect idle, perfect driveability, everything.
I'm compelled to repeat it will do any one of these things between turning the car off and starting it again immediately, there appears to be no rhyme or reason to any one of these behaviors.
Engine codes: none!
What I've already replace: IAC, TPS, Fuel filter, fuel injectors.
What I'm thinking: Computer, Optispark, or plugs and wires, maybe EGR?
ive gotten to the point where the next things I have to start replacing arent super cheap or easy like the other stuff, ao I was hoping based on this info or any I could provide if you fine folks could give me an idea of which is the most likely to be causing this schizophrenic ossiclation between high idle, no idle, and running perfectly. every time I turn the key it's a crapshoot what it will do.
thanks!
Engine codes: none!
thanks!
