L
levi_elston
I've had my 92 LT1 auto convertible for 15 or 16 months now and no transmission troubles until last month. I was going on a road trip, and I got about 30 minutes into it and the torque converter unlocked at about 80 mph (was just cruising). Naturally I pulled off the freeway and check the fluid which seemed to be hot and high if anything but definately not low. Anyways, I put it back in gear and it would not shift out of first. Stopped again, check fluid that was still hot and shut off car for 15 minutes or so. Tried to drive again and wouldn't shift out of first, and luckily had a friend that live 7 miles away and was just gonna cruise over there and park it. Got about 3 or 4 miles down the road and then it shifted through fine. Loaded it on a trailer and brought it to a friend (about 2 hours away) that is a mechanic who looked over it, drove it some and could not get it to act up. I went to get it and drive it home and drove the 2 hour drive with no problem at all. Later that week (just a couple of days ago) I got on the road to my father's house (40 minutes away) and it started acting up again about 5 minutes from his house except this time it would shift up or down out of second gear, and eventually it would kinda slam into overdrive and lockup. Checked fluid, seemed a bit burnt, hot, and high again. I waited a couple hours for it to cool off and was gonna drive it home or to a shop. Drove all the way home with no hangups (drove it in drive the whole time to pump more fluid, but did bump it into overdrive a couple of time without any trouble). I have no idea what is going on? any suggestions? I've done lots of do-it-yourself work(replaced optispark), but don't know much about transmissions. All help is very appreciated! Thanks
