VetteLuv
Vette starts & runs great until it warms up to about 140f then it "stumbles" or dies completely. This happens when driving or at idle in the driveway.
An electric failure is indicated as all gauges "die" with the engine. When motor dies completely it will restart immediately with a turn of the key and will run & drive without any problem whatsoever. The "Service Engine Soon" warning light is set and stays lit until car is off for several hours.
Reading the error code indicates a malfunction of the Optispark: signal drop-out. Optispark was replaced just before going into storage for winter of 2014-15 and Vette ran OK for that very short time. Last summer started OK but started having the problem in September after only about 1,000 miles on the new Optispark (Limited driving due to health problems). After another winter of storage the problem continues (as does out winter weather). Before taking the car to a plug&play repairman who will probably want to replace the Optispark, and the almost new water pump, does any C-4 wizards have any suggestions and/or solutions.
Thanks,
Bruce
Thanks,
Bruce
