echo4golf
Hi Folks,
Having an issue with the courtesy lights in my '93. The issue started with the lights flashing on and off randomly while driving and progressed the lights staying on all the time--even after the DAB should have shut them down. I tried adjusting the switches and wound up replacing one of them to no avail. I pulled the codes and got a 25 (Courtesy lamp relay coil open or shorted to ground.)
The ground seems to be OK. But when I trigger the relay, there is an audible buzzing. The lights go on and off this way.
Right now my plan is to replace it. Here's the catch: I can't get to it. In the FSM, it looks like it's behind the passenger's side knee bolster. The diagrams shows two sets of relays, one with three and one with two. I pulled the bolster and found the one, but the other seems to be hidden out of reach. I can hear it buzzing away back there too, but can't seem to locate it.
Does anyone know, can I pull the glove box to get to it?
Or am I stuck trying to work upside down and backward in the passenger's seat. I'd rather not pull the seat, although I guess that's an option. (Of course, if I pull the seat, I can strip the cover and repair the inflateable parts.... But then I'd have to do the driver's side. And while I'm at it... NO! Daggone sequences will get you every time.)
Thanks,
Jerry
Thanks,
Jerry
