93 cruise control wiring diagram
  • Thread starter Thread starter whsteele@bellsouth.net
W
Need to locate a wiring diagram for my 93 coupe to trace down failure of the cruise control to engage. Anyone know of one online or where I can secure one?
Cruise control
On my '94, my cruise control and the air vent / heat registers wouldn't work.
It turns out there is a plastic T vacuum valve under the passenger side rocker cover (under the corvette plastic shield cover ) that had a hole in it.
I replaced it and instantly they both started working again.
Hopefully your '93 has the same set up and for less then $10 bucks, you will be all fixed up.
