94conv.
Ok Ive posted here about this not to long ago, but the problem or lack of diagnosis is still present. First off, after a long 5 hour drive I came home, the car sat for about two hours, and then I started it to take it out again, it idled real low, 500 and slightly below, stumbled. Shut it off, cleaned the IAC thinking it was carboned up. Hooked it back up and started it. Idled to 1500 then down to 800 where it belongs, thats what it keeps doing now, I just checked for any vacuum leaks and didnt find any. Sprayed throttle body cleaner, highly flammable around the connections, no change whatsoever. I'm thinking its the IAC motor going bad. Once it idles down it runs great, its only when you start it that it revs to 1500 and then down to normal, within a few seconds, maybe 10. Any advice or anything else Im missing before I order this 90 some dollar part? I am going to Gm to get the part this time, I think I replaced that IAC about 3 years ago and got it from advanced auto and it cost like 40 bucks, gm's is more the twice that with a different number that doesnt cross reference the number that I just got a week ago from O'rielys which is also about 40 or 50 bucks. I also unhooked the IAC and started it and it went to 1500 and stayed there, didnt attempt to come down. so I plugged it back in and once again it went to 1500 then back down to 800.
Thanks.
Thanks.
