'94 LT1 Fuel Pressure Regulator—Location??
Donne Trav
Washington, DC
1994 Blk/Blk
Where is the FUEL PRESSURE REGULATOR located on the '94 LT1 Corvette?
Is it easy to replace? ;help THANKYOU
on top of the engine, on the back drivers side fuel rail. close to the schrader valve ( place where the pressure gauge goes.)
Follow the two braided steel hoses that come from the passenger side up to the engine.
One goes directly into the fuel rail ( with a schrader valve) and one goes to the regulator.
AS far as being hard to replace, its not that hard. However, you may want to get a manual to familiarize yourself with the connector on the regulator and how to manipulate it.
Also, keep in mind the gas will be under pressure. wear goggles and keep some rags handy on first disconnect.
