WillC4
So, i recently had my PCM professionally tuned for the vette. I gave it a good test drive for around 40 miles and the car seemed to run pretty well. My cooling fans are tuned to turn on at 182° and off at 172° to compliment the 160° T-stat. I pulled up into my driveway and felt that my idle RPM was a bit high and then switched on my manual fan switch. I temporarily leave the car to set up the parking space and when i come back, the "Service Soon" light was on. I quickly pulled into the spot and turned the car off, then back on again at the time the RPMs bounced up and down a little bit ( seemed to bounce up and down in 300 rpm increments). I then turned the car off and waited a couple of minutes, then started the car up once again, this time the idle was steady, but the light remained on. I walked to the front and noticed that the both cooling fans were on, so i went in and turned the manual switch off. The temp gage read 163°, so i thought why are the fans still on, they should be off by now. I then shut the car off and unplugged the battery to reset the computer. I started the car again, and now warning light is off now and the fans come on and off automatically like they should be. I suspect that when i turned on my fan switch, it probably shorted the fan relay circuit. Ill be watching it closely for the next few days, but does what i suspect sound like the most likely culprit?
