caddy
Could someone give me a little insight on the removal of my seats (getting recovered) from my 94 LT1 coupe 6-speed?
As jmccloud said, remove the bottom cushion, then remove the four bolts attaching the seat to the car. You will have to disconnect the power connector if you have power seats. I think there are little plastic covers over the front bolts that are easy to remove. Pretty simple to do.jmccloud said:There's a wire fastener in the lower front center (almost under the seat) that will release the lower cushion when pushed in and down. It's a little difficult to release.
Once the lower cushion is out, everything else is much more accessible.
