compyelc4
- Joined
- May 1, 2002
- Messages
- 609
- Location
- Dayton, Ohio
- Corvette
- '95 LT1 Coupe, Comp Yell; C6 Roadster, Vel Yell
Want (not need) to replace coil wire (42K miles). The coil end is corroded somewhat but engine runs well just the same. Anyway, how easy is it to replace the wire without removing the water pump? The fit looks tight. If this is a PITA I just might clean up the coil wire and pop it back on the coil with some dielectric grease.
