Here is the scenario. My drive home from work takes about 30 minutes and contains highway and stop-n-go traffic. By the time I pull into my garage the car is idling rough. The air temp has been 80+ and the car coolant temp is between 220-230. I let the car cool for a couple of hours and it will run fine again for another 30 minutes. (Lather-rinse-repeat). With some advice in this forum and my neighbor a seasoned corvette mechanic I have completed the following repairs and maintenance checks:
- replaced plugs and cables.
- cleaned TB and AIC valve.
- replaced EGR Valve.
- checked all fluids levels and for leaks (oil, trans, coolant). All check out ok.
- checked for computer codes. There were none.
The car seems to run fine until it reaches the higher temps. The car has 98k miles but I have done regular maintenance as long as I have had it.
I am not sure what to try next. Any help would be appreciated.
bnhynum
bnhynum
